Old 07-29-2007, 02:05 PM
bap bap is offline
ac compressor not cycling?
My AC on 96 Taurus wagon doesn't seem cold enough. It works but not enough to cool the car. Noticed today that there doesn't appear to be the telltale cycling you normally hear with compressor. System was recharged recently to 25psi. Suggestions?
Old 07-29-2007, 03:55 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: ac compressor not cycling?
either the charge has leaked out or never got enough charge to work properly
-=-=-DANE-=-=-
Old 07-29-2007, 10:58 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Also, since your 1996 would be the R-134a system, and overcharge condition could also cause poor performance. In an R-134a system, undercharging and over-charging yield similar symptoms.
What is the compressor cycling duty cycle (time on compared with time off)?
-Rod
Old 07-29-2007, 11:26 PM
RickMN RickMN is offline
Rod is right on the money about the charge volume. The "window" on over/under charging on R-134a is less than 3 ounces. The DIY kits are only accurate to within about 3/4 lb. Plus, the pressure varies depending on the outside temp when you charge the vehicle. My guess is that you're overcharged, so the compressor isn't cycling and the overcharge condition is why you're not cooling.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 07-30-2007, 02:56 AM
Mediarocker543's Avatar
Mediarocker543 Mediarocker543 is offline
Send a message via ICQ to Mediarocker543
Had the same problem, Took 1 DIY Leak stop by Interdynamics and 3 cans of DIY 134a+ by Interdynamics. Now it cools within 6-9 seconds
Just dropping some input from personal experience.
