Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-29-2007, 01:16 PM
hotlantabrave hotlantabrave is offline
3sp auto W/od stuck in 2nd
I have a 95 Eclipse GS with a 3 speed automatic transmission with overdrive that intermittently gets stuck in 2nd gear (safe mode?). Took it to a local transmission shop and was told that the code said that engine was out of time and because engine was running poorly it MIGHT be causing the transmission to go to safe or fail safe mode. I had a new timing belt put on and engine is in time now, but it happened again last night. If I let car set for a while, it will shift OK. Seems to happen on the down shift from third to second when slowing. Any suggestions or recommendations.
Old 07-29-2007, 09:41 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 3sp auto W/od stuck in 2nd
3 speed auto...? Since when did they ever put one of those in a 2g?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-30-2007, 09:38 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
There should be a vacume line that runs into the transmission, I'm not sure where it is but I know most auto trannys have it. It lets the transmission know when to shift by reading vacum pressure from the motor. Check to see if yours is hooked up properly (look in a chiltons manual for location). If that doesnt fix it your best bet will be to take it to the tranny shop.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
