94 explorer running bad
strange problem i cant seem to pinpoint
94 exp, 4.0 sohc, 4x4 idles fine, maybe a tiny bit rough. rpm range good with no load, revs fine. driving though it has no guts, and it will not go over 2500 rpms, bogs out when i stomp on it, max speed of 50mph. new coil pack (tried 2) plugs wires swapped out the maf sensor, it ran better but still boggy after 2500 rpms. fuel pressure perfect throughout load and unloaded engine, idle and key on engine off. new fuel filter new air filter no codes either............ any ideas would be much appreciated its just funny, idles and revs fine not in gear, even stomping on it, its ok, under load it bogs like a mother... oh yeah, dropped the pipe before the cat and still no change, except the loudness, so the cats arent clogged either thanks a ton!
1998 Ram 1500 SLT 4x4 5.9L Dynomax Performance Dual Exhaust KN cold air intake Bosch +4 Platnum Plugs 180 Degree Thermostat I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot. |
Re: 94 explorer running bad
Did this just start after performing some maintenance, or out of the blue?
Have you checked for vacuum leaks and made sure your spark plug wires are in the correct order? -Rod |
just out of the blue, theres no misfire at all, it seems not to be getting enough air, or fuel, though the fuel pressure is within specs. like i said it idles ok and revs ok in park, driving its awfully boggy
