Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-28-2007, 05:08 PM
goofinoff goofinoff is offline
Where is knock sensor on a 1988 Delta 88?
My first post here, CEL came on and I pulled a code 41 and a 43. I found cam sensor, but the details in my Haynes manual do not show where the knock sensor is located for my specific engine. It is a 1988 Delta 88 Royale Braugham 3800 V6. Can anyone tell me where the knock sensor is located, or possibly provide a link to factory engine spec.s for my car online? Thanks!!
Old 07-30-2007, 08:33 AM
Re: Where is knock sensor on a 1988 Delta 88?
Still could use some help here. Can't find anything , been searching online for awhile now - any info would be appreciated. Thanx!!
Old 07-30-2007, 08:55 AM
marc-o-matic marc-o-matic is offline
depending on witch engine
lower right corner of engine block
or
top of block by transmission-under throttle body
Old 07-30-2007, 11:21 AM
Thanks marc-o-matic, it is a 1988 3800 V6. It is not under throttle body. When you say "lower right corner of engine block" I assume drivers side, firewall side. I will look there tonight after work, I remember the exhaust and some tranny lines, etc. being back there, so hopefully will find it. Would it be best to look from underneath - or from the top?? Thanks again - I truly appreciate this. kurt
Old 07-30-2007, 11:33 AM
Look from underneath,check both sides of engine block.(The info isn't very clear)
Old 07-30-2007, 03:32 PM
Mickey#1 Mickey#1 is offline
I'm don't know if the 1988's have a knock sensor. Isn't code 41 for Cam Sensor & code 43 for Electronic Spark Control?
Old 07-31-2007, 10:01 AM
Code 43 is electronic spark control, and when I read further into the diagnosis, it also points to knock sensor. I know how to replace sensors, but the electronic spark control is not supposed to be repairable (like a points/distributor ignition), so i want to check connections to knoock sensor if I can. I am still wondering why it would throw a 41 and 43 together. Thanks for your responses.
