Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 07-28-2007, 05:05 PM
fireman48 fireman48 is offline
Unhappy vibs bad when in gear
I have a 2002 eclipse gt and been trying to figure out what would cause bad vibrations. It will only do it once engine is at opperating temp and in drive at a stand still. I took it to 3 diff. mechanics, they messed with bypass screw but couldn,t pin point problem. I installed new motor mounts a while back and tested the idle motor, and if I tested it right than the motor is bad. Any help would be appreciated!
Old 07-30-2007, 09:26 AM
808drifter 808drifter is offline
Re: vibs bad when in gear
What mounts did you install?
If you install the deymene (<spelling?)
firm mounts then it's gonna vibrate no mater what.
Old 07-30-2007, 11:59 AM
I installed polyerathane mounts, and I know this will cause vibs but it got alot worse since then.
Old 07-30-2007, 12:02 PM
Weird that it does it at operating temp and not cold.
Old 07-30-2007, 01:06 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
torque converter? i don't know much about auto tranny's so it might be that or the fluid.
Don't act like you don't love it.
503/2000
