Old 07-28-2007, 12:34 PM
watermelon-man watermelon-man is offline
1998 Ford F150 XLT 4.6
My truck started missing and also backfiring a few weeks ago. Replaced sparkplugs and wires. It quit backfiring but is still missing. Replaced the fuel injectors last weekend but it still misses.Does anyone know if a bad ignition coil could cause this problem?
Old 08-12-2007, 11:49 AM
Willore911 Willore911 is offline
Re: 1998 Ford F150 XLT 4.6
Check engine light on? If so, what codes are given when a scan tool is used.
Old 08-12-2007, 02:07 PM
rhandwor rhandwor is offline
My 1997 had a coil for each sparkplug if this is the case a bad coil will definately cause a miss. If you check codes it should tell you which cylinder is misfiring. Auto Zone and Advance do this as a free service. I assume they will you to buy a part from them.
A bad pressure regulator can cause a miss by causing some cylinders not to get a proper mixture.
Old 08-12-2007, 02:19 PM
2001jettavr6 2001jettavr6 is offline
also make sure your gap in your spark plugs are correct for the vehicle
Old 08-12-2007, 03:23 PM
wafrederick wafrederick is offline
Banned
Do a compression test on the cylinders also,it could be a "dead cylinder" and a compression test will confirm that.
