Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-28-2007, 11:59 AM
pipe539 pipe539 is offline
Turn signals?
Hello I have a 2000 Sunfire, I ham having a problem with the turn signal. What it will do is when I engage the switch the blinker will work a few times and then quit, this will happen on either direction. then after the initial time the switch will only work one blink and stop. the Hazard lights work normally.
What I have done, I checked the 10a fuse for the turn signal, OK. Found the relay under the dash and found that I get power from the battery and the ignition terminals but not from the Hazard terminal or turn terminal.
What else is there that i can look at? or is the relay bad?
Thanks
Where ever you go, There you are.
Old 07-29-2007, 05:41 PM
ChemMan ChemMan is offline
Re: Turn signals?
Go ahead and replace the turn signal relay. It shouldn't be too expensive and is most likely the culprit. Hopefully
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 08-08-2007, 03:56 PM
Re: Turn signals?
I replaced it and it works like new thanks
