Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-28-2007, 12:09 PM
captclydejc captclydejc is offline
93 ThunderBird PROBLEM???
Can I bypass the A/C compressor, and what size serpentine belt is needed?
Old 07-28-2007, 08:58 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 93 ThunderBird PROBLEM???
Welcome to the forum. You have to be sure the belt travels in the correct direction around all the other pulleys if you bypass the compressor. Not being near my cars to check and not knowing what engine you have, I can't say if when bypassing the compressor you will have a straight line between the two pulleys on either side of the compressor pulley. If you do, tie a string around the path of all the pulleys and take it to your suppy store and have them match up the length. Remember to get it a little smaller then the size of the string to account for the belt tensioner being in the relaxed position.
The Original 97Bird
Old 07-31-2007, 09:18 PM
Decipha Decipha is offline
wrap a string around the pulleys in the same manor as the belt would travel and get a belt 1 inch shorter, then work from there till you get a belt that fits nicely
btw i'd dump the smog pump if possible
sry mods i'll try 2 b good
Old 08-01-2007, 08:07 PM
97Bird's Avatar
I do believe there is an echo in this forum!! HELLLLOOOOOOOOO
The Original 97Bird
