Old 07-28-2007, 03:01 AM
elgueaga elgueaga is offline
removing top bolt from stuts
how do you remove the top bolt from the struts it spins when i use a ratchet
i AM TRYING TO REPLACE THE FRONT STRUTS ANY HELP WOULD BE APPRECIATED
2002 grand am 2.2 ecotec
Old 07-28-2007, 03:33 AM
doug2060 doug2060 is offline
Re: removing top bolt from stuts
Have you got the strut off the car yet? (If not you dont have to touch that center bolt yet)
Old 07-28-2007, 03:56 AM
i have gotten it off twice before first got it off thinking i all the tools i needed top bolt was a problem 2nd time bought offset wrenches thought it would work failed
Old 07-28-2007, 10:50 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
You only need to remove the 3 mounting bolts to remove the strut.
Then when the struts off use a wrench or visegrips to hold the damper shaft.
Then remove nut.
Dont forget the coil spring compressor !!
You'll loose some teeth if you dont
1999 Grand Am SS 3.4 OHV
Old 07-28-2007, 11:55 AM
Jmoney3318's Avatar
Jmoney3318 Jmoney3318 is offline
Send a message via AIM to Jmoney3318
yea be careful bro wen i put new springs in, that center bolt pops the hell up when it comes off
my Cardomain
2002 3.4L V6 GA Coupe
-Xero is my hero--
mods:
Suspension: KYB GR2s, Intrax Lowering Springs, Upper Front Strut Bar
Engine: Custom 2.25" Exhaust,Doctorspeed Cold Air Box
