Old 07-28-2007, 12:52 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Stripping help
Okay please don't kill me on this, but recently i have been trying to strip a body and nothing seems to work. I have used dupli color laquer and another type of laquer that i dont remember. I have tried using :
Purple Power = Nothing
Brake Fluid (Dot 3) = Nothing
93% Rubbing Alcohol = Nothing
I haven't tried CSC, but i think that won't take laquer off. Also i've been trying to find Dot 2 Brake fluid, but can't seem to find it anywhere, napa and autozone doesn't carry it as its an older type of brake fluid. So help me guys, where can i find dot 2 and will CSC help at all?
Sorry for the repetitive question, i did search before posting.
Mark
In Progress
Old 07-28-2007, 06:00 AM
MidnightWangan's Avatar
MidnightWangan MidnightWangan is offline
Re: Stripping help
Hi, saw your post, it didn't mention for how long you soaked the kit. Duration seems to matter as well as the freshness of the brakefluid, i recently stripped a kit that was done 2yrs+ ago, with a new batch of brakefluid, it took almost a week of soaking just to eat into the clear coat. As the brakefluid seeps into the layers, brushing away the dissolved layers periodically also helps.
Old 07-28-2007, 08:39 AM
jmwallac's Avatar
jmwallac jmwallac is offline
Re: Stripping help
Unfortunately, I am getting to be an "expert" on stripping paint.
I use duplicolor almost exclusively, and have had good luck with 91% rubbing alcohol. It takes a few days, but eventually it gets under the clear and color coats and starts to slide off. I've also found that if you let the 91% evaporate, the paint shrivels up and flakes off. But it has to soak for a while; at least 3 or 4 days at the minimum.
I'm convinced DOT3 couldn't get a Vegas stipper out of her clothes. It has never budged any paint for me. I've read DOT4 might be a better choice?
Good luck. You can always grab some sandpaper and start sanding it off....
Recently completed projects:
Old 07-28-2007, 10:22 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Stripping help
If you've tried Purple Power, CSC won't do anything different- they're essentially the same product.
I'd be tempted to try 99% denatured alcohol- you can get it pretty easily in the paint dept of home improvement stores. It may or may not do more than 93%. But I'm certainly surprised to hear that there's no effect with 93%.
PHOTOBUCKET SUCKS
Old 07-28-2007, 10:37 AM
ZoomZoomMX-5's Avatar
Re: Stripping help
I'm surprised the brake fluid isn't working.
You may also try Dawn Power Dissolver, some say that works great.
Polly S Easy Lift Off generally works on everything.
You may simply need to sand/scuff the paint surface to give the chemicals a better chance to eat into the paint; though any of the castrol or purple power stuff seemingly has no effect on lacquers.
I'd scuff the surfaces and try immersing in the 91% or 99% alcohol, if that doesn't work then go for brake fluid or Polly S.
If there's a chance that the outer layer is enamel rather than lacquer, coating it with Easy Off heavy duty oven cleaner may do the trick, but it works far better on enamels than lacquers.
My Fotki Album
Old 07-28-2007, 12:59 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Stripping help
Just so that you know, I've never stripped paint from a body using chemicals. The one time I did have to strip a body, I just carefully sanded everything using 3M 600 grit paper and Automotive 1200 when I started to see primer. Probably not the easiest thing to do but it worked.....
AF's Guidelines
Read them.
Old 07-30-2007, 03:24 AM
mrawl's Avatar
mrawl mrawl is offline
Re: Stripping help
Feels dumb repeating this info, but we'll blame the question. Try Scalecoat from your hobby store, it's extremely effective in around 10 minutes. If it's proving really tough, try giving it a bit of a scrub with a tooth brush from time to time while it's soaking.
Old 07-30-2007, 05:47 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Stripping help
Click on me
If even DOT 4 doesn't work (after soaking it for 24 hours or more), then I would suggest some more dangerous products. Those that come to mind : Acetone (AKA: nail polish remover (well at least most of them come with a high percentage of it)), lacquer thinner, Mr Paint Remover (GSI product). These are used in an apply and wipe method. Leaving these products on your model for too long WILL damage the plastic underneath.
As mentioned before, since you didn't tell us how long you left the model in the products you mentioned, suggesting a better solution is a tad more difficult.
HTH,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
