Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-27-2007, 11:07 PM
rubble2269 rubble2269 is offline
92 Sohc A/t Into 94 Dohc A/t
Will an automatic tranny from a 92 SOHC fit into a 94 DOHC (w/bad tranny) in other words swap the 92 tranny into the 94?
W/O messing with the ECM?
Can someone explain to me exactly what the transmission valve body does, and how much it does or does not affect shifting?
The 94s tranny shifts initially but then goes into limp mode? Can anyone help explain?
Thank You.opcorn:
Old 08-04-2007, 11:05 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 92 Sohc A/t Into 94 Dohc A/t
they will not interchange, gear ratios are different. the propose of the valve body is to control the shifting, it directs fluid through the transmission to hydralicly control gear engagement. you problem could be several different things, i suggest a professial diagonsis at you local dealership.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
