Old 07-27-2007, 10:12 PM
X2Xtreme360 X2Xtreme360 is offline
Removing EGR from manifold
For a while, my EGR pipe was hanging with no support b/c me new phlenum had no spot for the EGR. Well after sitting for so long eventually the pipe snapped off and now I have exhaust flowing into my engine bay, and getting some things nasty. I cant seem to fit anything down to the exhaust manifold to remove the egr pipe from it. For anyone whos removed it, what the hell did you fit down there to remove the pipe from the manifold?
Also, If anyone has any pictures on how to wire a resistor in to get the EGR CEL light to disappear, id appreciate it.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 07-28-2007, 08:41 AM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Re: Removing EGR from manifold
hmm..so you need to block the egr off the exhaust manifold? well i removed my EGR, but i bought headers and only needed to block it off my intake manifold..idk..take off the rear exhaust manifold and weld something over the spot? thats a tight area to work with while on the car..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 07-28-2007, 08:46 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
remove your intake plenum. then it will be easier to access the rest of the EGR connected to the exhaust manifold. get an EGR block off plate or get creative and make your own out of metal and a dremel.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-28-2007, 09:18 AM
ya but he doesnt need block off plates, his intake manifold doesnt have spots for the EGR..just needs to some how cover up the hole where the egr was on the exhaust manifold? i beleive thats what he is saying
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 07-28-2007, 09:31 AM
Linebckr49's Avatar
i get what he's saying, but he'll need a kind of block off plate to cover the place on the exhaust manifold. but you can make your own block off plate instead of spending $25 and another $10 on shipping and waiting 3 days for it to arrive.
93 3000GT base
Old 07-28-2007, 09:36 AM
ya i agree..very easy to make if you have the ability to..i made mine, same difference..you barely see them anyways..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 07-28-2007, 12:05 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I dunno about the DOHCs but the SOHC egr pipe has like a nut on the end where it meets the exhaust manifold. When my pipe broke off I cut the pipe about 3 inches back from the nut and unscrewed it off. I then clamped the pipe shut and welded it and put the nut thing back on. You could also just try to find a cap type theng to screw on there, maybe something in the plumbing section of a hardware store.
http://www.3si.org/forum/showthread.php?t=382054 for the resistor mod.
