Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 07-27-2007, 09:03 PM
90b16acivic 90b16acivic is offline
90 b16a in a 92-95 civic
i was wondering if i could put a 88-91 b16a with a ys1 into a 92-95 civic without needing new motor mounts? Can i just keep the mounts that r on the b16a and take the mounts out of the 92-95 civic and swap it or do i need totaly new mounts?
Old 07-27-2007, 09:26 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: 90 b16a in a 92-95 civic
You'll need a custom transmission side mount kit to be able to use the cable transmission with the 5th gen (that's set up for a hydraulic tranny). You'll also need an OBD1 ecu.
Old 07-28-2007, 04:10 PM
Thanks for the info....but do u no if i can swap the engine with out having to buy new motor mounts?.....do u no how much a odb1 ecu is????.....
Old 07-28-2007, 04:30 PM
CivicSpoon's Avatar
There is no Spoon
Well, if you were to use a hydro B-series transmission, you would just need the B16a driver's side mount and b16a rear mount bracket and be able to use the rest of the stock '92-'95 Civic mounts. I'm honestly not sure how different the '88-'91 b16a and '92-'95 b16a mounts are. So as long as the mounts are the same you'll be fine, otherwise you'll need to get the compatible b-series mount and mount bracket.
As for the ecu, it depends on how much you can find it for. I've seen them go for $180-$300.
Old 08-16-2007, 04:51 PM
ByonSho ByonSho is offline
how much is this trans mount? I have a94 del sol with a B16a and it's not sitting straghit and I think the wrong trans mount is being used.
Old 08-16-2007, 05:45 PM
CivicSpoon's Avatar
There is no Spoon
The mount is $200: http://www.hasport.com/products/mount_kits/egbcc.htm
