Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-27-2007, 08:55 PM
ABigWeaney ABigWeaney is offline
bearing question
OK i have a 92 tsi and i am in the process of a build i already got wiseco pistons, eagle rods, crank and some other stuff and i was wondering what kind of bearings would be good for this stuff. I need them to support up to 300 hp
Old 07-27-2007, 10:03 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: bearing question
Clevite bearings and ARP hardware. But if you are spending the cash on a build, you should invest the small amount of $$$ getting a 90-91 6 bolt block>less prone to crank walk. Well worth it.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 07-28-2007, 05:39 PM
it is a 6 bolt.
Old 07-29-2007, 11:09 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah I went with Clevite bearings when I did my build...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-30-2007, 10:58 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Same. Clevite Bearings, ARP hardware
1991 GSX 2.3 Stroker
