98 century split zone AC not working right
Passenger side does not cold air. Drivers side is cold. I have disconnected the battery for a short period of time and the problem will go away obly to return after a short while. What could be the problem?
Re: 98 century split zone AC not working right
The climate control system uses temperature control actuators. The dual zone system has one for the drivers side and one for the passenger side. These control blend doors in the lower HVAC assembly. You can check the operation of the temp. actuator. The passenger side one is located behind the glove box to the upper left.
hello. my parents 99 century has the opposite problem. hot air on drivers side, cold on passengers side. i changed the battery 4 days ago, and no other mechanical work has been done recently. where is the drivers side temp actuator located, or what else could i look for to try and clear up this problem? any help appreciated. thanks, greg. |
Should not make any difference but the important part is make sure the climate control is turned to the OFF position. But just make sure the temperature controls are adjusted for the coldest position. Then remove battery negative cable, let sit a short period of time and then reconnect. You may have to repeat.
thanks, greg. |
Are you sure that the system is not low on refrigerant? You will need to check the high & low side pressures for best and more accurate results. Same thing happened to my PA several months ago, it was 8 oz low. Charged it up and now the temps are the same on both sides!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Am I confused, or are you confused. In your first post (First quote above) you said "passenger side does not get cold"! In your most recent post, you said; "since it is coming out at 47 on the passengers side, and about 59 on the drivers side". Which one is correct?
I agree with HotZ28. Standard procedure when there is uneven cooling across the evaporator core and driver's side is not as cold as passenger is to check the refrigerant charge. It should correspond to the ambient or actual temperature.
I see the OP and the second poster are not the same so a little confusion. Best to start your own post and not bootstrap off anothers.
