Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-27-2007, 07:08 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Cluster lights don't work. '98 RS
My instrument cluster has no light, that is i can see the check engine light and the seat belt but the background is not illuminated. My front head lights are working just fine. Any ideas?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 07-28-2007, 12:06 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Cluster lights don't work. '98 RS
It may just be a fuse, check all of them and if they are all fine then I guess you have a different problem. All the bulbs wouldn't go out at the same time so it has to be an electrical problem. You will just have to stay testing shit to find out what it is. You might want to check you dimmer switch to. I have heard of them going out. Use a volt meter if you have one.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-28-2007, 10:20 AM
JoeShmoe's Avatar
YEah when i got the car the guy pointed out that it might be the dimmer. I have a volt meter but how do i test the it? Isn't it just a knob??
Old 07-28-2007, 10:22 AM
Holset powered 420a
Yes thats the dimmer, Pull the panels off so that you can get to the back of the switch, then just ground the volt meter and check all the wires for power. Turn the switch down to see if the voltage drops. Im not sure if all the wires are suppose to have power or not so your going to have to figure that out.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-28-2007, 10:28 AM
JoeShmoe's Avatar
Cool man, anything to keep in mind when pulling the panels off?
Old 07-28-2007, 10:35 AM
Holset powered 420a
umm... start with the kick panel under the steering wheel. I think there may be some screws in the bottom and maybe 1 under the pop out square, then its just clips. You should be able to reach the dimmer from there.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-28-2007, 10:47 AM
JoeShmoe's Avatar
Rightous, I'll get right on it. Thanks a lot man. By the way, I'm Jose. I've always admired the Eclipse, I finnaly get to see what I can really do.
Old 07-30-2007, 08:55 PM
JoeShmoe's Avatar
I checked the voltage on the dimmer and i got voltage from 2-12 with the dimmer on. All the fuses are good and i still fet no lights. Honestly i don't know where i was supposed to check the dimmer on. I only toook the switch of the bracket, was i supposed to take the cover off the switch itself?
Old 08-01-2007, 07:06 AM
JoeShmoe's Avatar
Does anyone know where exactly i'm supposed to measure the voltage on the dimmer?
Old 08-01-2007, 09:44 AM
Holset powered 420a
hmm I really dont know. I would guess just plug it in and mesure the output on the wires. If the dimmer switch controlled the voltage on one of the wires then thats probably the one that goes to the cluster. Which means you have another problem.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-02-2007, 12:43 PM
JoeShmoe's Avatar
Are the cluster lights replaceable? I'm getting power from and to the dimmer just fine. Could it be that the wire is bad under the cluster, or maybe one of the bulbs went out and now they are all out? Either way I think i'm gonna have to remove the whole dash.
Old 08-02-2007, 08:41 PM
Holset powered 420a
Just pull the cluster out, you dont have to remove the whole dash.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-05-2007, 03:47 PM
JoeShmoe's Avatar
Well actually I'm gonna take the easy way out and just install a toggle switch in the space where the dimmer went. Then i'm gonna mount some LEDs or maybe small neon bars to illuminate the cluster at least. Saves me the work of looking for a burnt wire or bulb, I'll match the color to whatever the whole cluster should have been.
Old 08-05-2007, 05:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
One cluster bulb going out will not affect the whole cluster. I've gone through the wiring on the clusters and it'll be fine if just one go out.
-Do your back tail lights work?
-Are the lights by the AC/Heater still on?
-And did you check both fuse boxes?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-05-2007, 08:25 PM
JoeShmoe's Avatar
MY tailights and my back-up light both work. My AC lights are no good, neither is the cluster. Both fuse boxes are good, that is all the fuses are good.
