Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-27-2007, 06:58 PM
KitsuneZero KitsuneZero is offline
Oil filter question
I usually pay someone to do my oil changes, but I'm going to start doing my own. I have a 99 GST.
Someone I work with also has a second gen Eclipse and he said the OEM Mitsubishi filters have a check valve in it to prevent oil draining out of the engine, or something to that extent. Any truth to that? If so, then would aftermarket filters have the same check valve?
I went to a dealer for an OEM filter and I ended up getting a MZ690072. Would that be the right one for my car? I believe so, but since I'm already asking about OEM vs aftermarket I might as well double check. I believe there are 2 different filters for the Eclipse.
Also, I was given a small copper colored ring about as big as the threads from the dealer, which the aftermarket filter did not come with. Is it a gasket?
Old 07-28-2007, 01:10 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Oil filter question
Not really to sure but I think I remember reading something about the stock oil filter having a valve but it was to close off the filter when at WOT. To make sure the motor had enough oil.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-28-2007, 02:13 AM
Killa's Avatar
Killa Killa is offline
for dsm, Im either run mitsubishi oil filter or pure one, nothing else. btw if you want get redline heavy weight shock proof gear oil ( mix 1 quart of redline and the rest is pennzoil, is utimate protection for that weak tranny ). I have 2 quart of you buy those I will throw in that mitsubishi turbo oil filter for free, need pix let me know.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-06-2007, 10:52 PM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
well i work at honda in survice and we have to put those ring thingies you were talking about on the drain plug so the oil pan won't get stuck to the plug.you dont have to use it but it will help you not to strip the threads.and no it doesnt go on the filter as a gasket
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
