Old 07-27-2007, 06:30 PM
windstarharv windstarharv is offline
Transmission trouble?
I have a 98 Windstar, 3.8 engine. When I first start the van and shift into reverse to back out of a parking space, nothing happens, no indication that the trans has engaged. I then shift into drive and then right back to reverse it will then engage. After that no problems. Does this sound like a trans rebuild or something simpler? Thanks
Old 07-27-2007, 06:40 PM
wiswind wiswind is offline
Re: Transmission trouble?
Let's hope that it is something simple, like the Transmision Range Sensor (TRS), also called Neutral Safety Switch.
This is located on top of the transmission, under that big flex hose that goes from the Air filter to the throttle body.
That is about the cheapest and easiest thing it could be.
The Transmission is electronicaly controlled.
I am not real optomistic.....but let's hope it is that easy.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 07-27-2007, 06:43 PM
Thanks, I'm not real optimistic either but the TRS is worth a try.
