| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Air/ Fuel problem
My air/fuel guage reads rich alot on ideal. My main problem is when I first start the car after it has been sitting for awhile and go to take off it skips and sputters like it's out of gas but I can press the clutch and stomp the gas and it quits. I was thinking that when I shut the car off it dont burn all the gas and then near about floods when I go to take off when I start it up later. What do yall think?
Re: Air/ Fuel problem
It could be a lot of things, but from what you're describing it might be a leaky fuel injector. If that's what's going on, the injector is pooling gas onto one of the cylinders after you shut off the engine (flooding it until it gets cleared out) because the residual fuel pressure wants to go somewhere.
Here's what ya do to check it: Connect a fuel pressure guage - hopefully you have a schrader valve on the fuel rail - otherwise you'll have to use adapters at the fuel filter to connnect it. Check the fuel pressure while the engine is running. While you're at it, make sure the pressure is within spec. Shut off the engine and watch the fuel pressure. If it drops significantly within ten minutes or so, then you probably have a leaky fuel injector. I'm not saying that this is your problem, I'm just letting you know how to diagnose the problem you think it is. |
What Air/Fuel guage do yall think is best? I have a Faze gauge and it is a piece of crap always changing from lean to rich will a wide band take care of that
