Go Back   Automotive Forums Car Chat > Volkswagen > Rabbit
Old 07-27-2007, 04:15 PM
AtomChurch AtomChurch is offline
Help 1979 VW Rabbit
I have a 1979 VW rabbit.
It tends to miss on i believe to be the first cylinder. I replaced the plugs and the wires. I have gotten a new injector and distributor. Something I have done that I probably should't have is put in those wax ball things to try and make the compression better. I have also added engine rebuild or whatever to try and do the same thing.
I checked the compression and Its low on the first cylinder but not much lower then the rest. Although they are all low at like 105 - 115. the number one is at 95. I added some oil and re-checked #1 and got 160.
Do you think this is bad rings? or could my regulator be faulty? Maybe a collapsed fuel line from the regulator?
I don't really want to change the rings but am up for it since this car is in almost new condition and is all original parts.
Also could I get a 1.7L engine in the same space as the 1.6L or wold i have to make new engine mounts and such?
-Atom Church
Age 18.
Old 08-04-2007, 01:45 AM
moparvwfreak moparvwfreak is offline
Re: Help 1979 VW Rabbit
it sounds like you got bad rings in the #1 cyl. i have a 79 as well and if its stock you should have an EH engine code which makes it a 1.5l.
now i have a few questions.
#1. do you have a bentley manual on this Rabbit?
#2. is it electronic ignition or have you done an electronic ignition conversion?
#3 is it carbed or CIS injected?
let me know and post a pic or two. here is mine.....
dodges, dubs, chevys and now fords. i am a glutton for punishment.
