Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-27-2007, 03:10 PM
Perdi Perdi is offline
Jeep Grand Cherokee 2.5 Diesel No ignition Lights
I have a 1997 Jeep Grand Cherokee Ltd 2.5 Diesel.
Sometimes the vehicle cuts out when driving along but restarts when the ignition is turned off and then on again. The problem is getting worse now and the vehicle sometimes will crank over but not restart, I have noticed that when it will not start, there is no ignition lights displayed on the instrument cluster, and anything powered by ignition does not work!when the ignition lights come back on the vehicle will restart, has anyone got any idea's? Is there an ignition relay somewhere hidden? or perhaps a bad connection at a multiplug?
Old 08-03-2007, 08:57 AM
JeepForever JeepForever is offline
Re: Jeep Grand Cherokee 2.5 Diesel No ignition Lights
I'm not sure the answer to your issue, but I'm curious about the diesel. Are you in the U.S.? I haven't seen diesels here.
There could be a loose wire or a short. Maybe an auto parts store can scan for codes to see if there's a sensor error.
Old 08-04-2007, 05:41 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Not US Diesel = UK
The cutting out and then restarting sounds like what I have seen people report prior to a crank sensor finally going permanently bad.
Are you just shutting off or stuttering to a stop?
Stuttering to a stop might be fuel pump related.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 03-24-2008, 08:01 PM
bx147 bx147 is offline
I have the same problem with a 1998 GC D Uk model Did you ever find out what was wrong = Please email me back yours Bob bx147
Old 03-27-2008, 04:59 PM
Hi its Bob Grahan a newbe from Bonnybridge Scotland = I was relieved to see your post as I thought that I was the only person with this problem = I have tried most things to get to the bottom of this but still have no answer = Sometimes when you flick the Ing Switch the lighs and gauges would come on = replaced Switch = NO change = if you keep yring to get it to go it sometimes flatens the battery = recharge Batt and it seems to work for a wee while = so I replaced the battery = Again No change = the list of what i have done and checked is endless = I even changed the Dash board as I wastold this could be a problem with the printed bit at the back = still the same = checked what I can ond wiring = still the same = Starts when you dont realy need it but if you are pushed = you just know its going to play up. = Please if you know the problem let me know = I will be dforever in yous debt = thats if I dont jump off a bridge someday when it wont start = Yours Bob
