Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-27-2007, 12:48 PM
mike561 mike561 is offline
Time for new belts?
I know im probably going to need new belts soon, and for them to be adjusted because of this as well, but when i first start up the car, and press on the gas i hear a loud squeak, only when i press the gas though, i have to let off it a few times for it to stop.
2006 Chevy Cobalt LS
Old 07-27-2007, 11:48 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Time for new belts?
Just try tightening them... it's usualy the altenator belt that squeaks when loose, but it could be others.
Old 07-27-2007, 11:55 PM
twistedtech twistedtech is offline
It don't matter how tight you make a hard bet, it will fail. The harder you make it, the less time it has.You have a hard belt!
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 07-28-2007, 12:10 AM
PeteA216's Avatar
Agreed, but it's not necesaraly a hard belt. You can have a new, rubberey one and if it's loose, it will squeal. I'm not eliminating the option, and odds are the belt is old and could use replacement, but it it's loose it needs tightening regardless.
Old 07-28-2007, 10:19 AM
ok so i should check the alternator belt then first
Old 07-28-2007, 01:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Check all of them! Don't do one first, do all at the same time! Yes, alternator belts can squeak, but you're more likely to get a squeak from a power steering belt or an A/C compressor belt.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-28-2007, 02:09 PM
PeteA216's Avatar
I've had A/C compressor belts loose enough to be able to work them the pulley without looseining then without any squeal. I've only found the altenator belts to squeal most often when revving the engine due to the fact that it's a small pulley trying to turn the heavy internal parts of the altenator. I do agree with silicon that you should check all belts, but I was just making a point when you open your hood, check the altenator one and go from there to the others (A/C Comressor, PWR steering which can often squeal while turning, and even the A.I.R. Pump)
