Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-27-2007, 01:35 PM
rocasan rocasan is offline
1998 Mercury Grand Marquis
The emergency brake light is blinking from time to time.
I never have used the emergency brake.
Please advise.
Thank you.
Old 07-27-2007, 01:45 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1998 Mercury Grand Marquis
First thing to do is to look and see if the fluid in the master cylinder is low. If it is low, have the brakes inspected for being worn down to the point of replacement. If the brakes are OK, look for a small leak. If brake fluid is OK, there is a switch on top of the e-brake assembly that may be faulty. Usually it is low fluid level. Especially if light flickers on acceleration, turns or fairly hard stops.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-03-2007, 01:47 PM
Following your instructions, I found the brake fluid was too low. I added brake fluid and the problem was correct.
Thank you.
