Old 07-27-2007, 10:37 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
My syncros hate me.
I was headed to work yesterday and at the light before the freeway entrance an Infinity FX45 pulls up in the right lane. I knew he needed in my lane and was going to gun it. When the light turned I let her rip. However, when I tried to get into second it wouldn't go. It would just sit there and grind until the RPMs dropped enough.
So I made two mistakes. I didn't launch the car and I have crappy syncros. Needless to say I'm bummed that the Stealth has a death on it now.
Old 07-27-2007, 11:03 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: My syncros hate me.
pull that tranny out lets get her rippin again!
Old 07-27-2007, 11:07 AM
Polygon's Avatar
The Red Baron
Only one problem, I don't know where to get a full set of syncros. Otherwise I would have done it by now. I've known the syncros had issues since I bought the car. I can only seem to find 1st and 2nd gear syncros from Kormex. Someone on 3SI was going to do a GB for some hardened syncros but that seems to not be going anywhere.
Old 07-27-2007, 03:16 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
why are you only finding 1st and 2nd at kormex? i got all exept 4th when i got mine done. did you call em?
Old 07-27-2007, 03:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
alright, lets get some things straight. there is NOT a synchro for every gear. a synchro allows for a smooth transition BETWEEN gears, but there is not a synchro between every gear. there are synchros for the 1/2 gear change, 3/4 gear change, and if you have a 5 spd, there is a 5/R synchro. or if you have a 6 spd, there is a 5/6 synchro, but no synchro for R in the 6spd.
so the synchros you need to find are:
-1/2 synchro
-3/4 synchro
usually the synchros for the higher gears last longer than the lower gears.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-27-2007, 05:39 PM
Polygon's Avatar
The Red Baron
So, you mean to tell me there is no syncro for the 2-3 gear change?
Old 07-27-2007, 05:42 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Like I said before, problems are like modifications on a 3/s, almost everyone has a few.
Old 07-27-2007, 06:34 PM
Polygon's Avatar
The Red Baron
Well, it shifts smooth as butter if I drive normal so I may be lucky and it might not be a syncro. I'm hoping a mix of Royal Purple Syncromax and 75w85 will fix the problem. However, when I shift from 2nd to 3rd, even when driving normal, sometimes it grinds.
Old 07-27-2007, 06:45 PM
jason_bet's Avatar
so you need the 3/4 syncro.. and lineback there is a syncro for every gear there is a syncro on each shift fork.. 1/2 use one sift fork 3/4 use one shift fork and 5/6 use a different shift fork..
so when you shift into third you are changing shift forks and useing the syncro that is between 3/4 gear
Old 07-27-2007, 08:15 PM
Polygon's Avatar
The Red Baron
Ahh, I see.
I'll admit, I don't know a great deal about manual transmissions. Nice to learn something new. So, the problem being that Kormex only has the 1/2 and they don't have the 3/4.
Old 07-28-2007, 04:18 PM
youngvr4's Avatar
STREET RACING GURU
its the blocking rings you need anyway
i got 1,2,3,5 gear blocking rings installed and grind gone...and never came back.
so maybe you need to call them and see if they have blocking rings
i just called em, and they have em for all gears.....its the blocking rings that go bad that causes the slip/grind you hear
there $80 a piece
Old 08-01-2007, 07:39 PM
Igovert500's Avatar
blue + red light magnet
Hate to say it but I'm starting to have problems with my 1st to 2nd shift at high rpms...which certainly hasn't helped in some recent races. Namely a Porsche 911 that I was having some fun with on I-95
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-03-2007, 08:42 AM
Boosted1 Boosted1 is offline
Most people seem to have problems with the blocking rings like mentioned above. Just a thought - I bought a blocking ring from Kormex (1/2 grinding), spent almost $500 to have it torn apart and replaced, and it did absolutely nothing. You may want to have it diagnosed just in case...
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 08-04-2007, 08:57 PM
Polygon's Avatar
The Red Baron
I'm going to try changing the fluid as a first step to see if that solves the problem. If not I'll go from there.
Old 08-04-2007, 10:00 PM
jason_bet's Avatar
if not.. i would say pull the tranny and bring in to me at the dealership.. grant has done a few and is good with the 5 speed tranny
