Old 09-17-2001, 03:22 PM
JE123's Avatar
JE123 JE123 is offline
How do you lower a car?
One of my kits that I have not started yet is an Impala from the 60's. I kind of want to lower it but I do not know how.
Old 09-17-2001, 09:23 PM
Jay! Jay! is offline
Horizontally Opposed
Tell us a bit about how the suspention is done. Is it all molded into the bottom of the chassis, like Guiddy's WRX, or is it a zillion pieces that you have to assemble?
Hierarchy of Subaru:
(Click to see mine!)
Old 09-18-2001, 09:00 PM
JE123's Avatar
This is what the suspension looks like. Here is a pic of the insructions: I hope this works because I have never posted a picture before.
[IMG]my pictures/model car.bmp[/IMG]
Old 09-18-2001, 09:13 PM
JE123's Avatar
I will try this again. This is the front.[IMG]C:\My Documents\My Pictures\model car.bmp[/IMG]
Old 09-18-2001, 10:08 PM
JE123's Avatar
This is the back[IMG]C:\My Documents\My Pictures\model car 2.bmp[/IMG]
Old 09-19-2001, 02:33 AM
Use the "Attach File:" portion at the bottom of the reply screen. PM me if you need help.
Old 09-19-2001, 04:00 AM
primera man's Avatar
"P-Man"
Cant see pis either.
To lower the car will mean a lot of work. Without seeing the pics....you may have to do things like the following that i have done for mine....remember this all takes a lot of time.
This is the 2 things i mostly do.
* Cut bits out of springs and shocks, then join them together again.
*Sometimes cut into the chassis if it is a one piece bit so it sets further ito the chassis.....(lots of mucking around)
View All My Models Here.
Old 09-19-2001, 06:46 AM
JE123's Avatar
Sorry I will try again. Front:
Old 09-19-2001, 06:47 AM
JE123's Avatar
Back:
Old 09-19-2001, 12:30 PM
Guiddy's Avatar
Guiddy Guiddy is offline
Easy!
With the front, make the suspension as per the instructions, but mount the top wishbone on to the chassis with another piece of plastic underneath, therefore rasing the height of the A arm.
With the rear, just cut a section of the rear shock and spring out, and re glue, as Warren said.
You will lose the strength of that part, so handle carefully!
Old 09-19-2001, 03:48 PM
JE123's Avatar
Thanks.
[How to] Lowering car models (example: fujimi integra) nomad_fsoak Car Modeling 3 10-18-2009 01:03 PM
how do you change oil and work on a lowered car? AznDragon Tires and Wheels 21 12-17-2003 10:18 PM
How do you lower your Fujimi models? BOOSTD Car Modeling 14 05-27-2003 10:23 AM
How do you lower the clutch pedal? gthang Maintenance 1 03-18-2002 09:21 AM
How do you lower the Fujimi Type-R? JDMTUNING Car Modeling 5 11-14-2001 12:35 AM
