Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-26-2007, 11:53 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Shuttering Clutch
I recently purchased a 1998 TJ with about 98K miles. The clutch seems to be really tight when depressing. I was told that a new high pressure clutch was installed.
The clutch seemed to be leaking off the pressure and making it difficult to shift in and/or out of gear when I stopped at a traffic light, even though no leakage is found. I though it was a bad internal seal in the hydraulics. So, I replaced the complete hydraulic system (kit). The shifting issue stopped but it still seems to require more then normal pressure to depress the clutch to the floor.
When I let the clutch out (while in first gear) the Jeep like shutters a bit while engaging. It only seems to shutter upon starting to move and it normal in all other gears.
I am looking towards having to replace the complete clutch because of the shuttering.
Does anyone have any input to other options?
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 08-09-2007, 09:21 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: Shuttering Clutch
Are the RPMs dropping too low? Maybe you just need to give it more gas.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
