Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-26-2007, 09:55 PM
4Bowties 4Bowties is offline
Dropping Fuel Pressure
1983 Camaro with a semi built 350 c.i. Demon 600, mechanical fuel pump. Here's the deaL, after about 15 minutes of running, my fuel pressure goes from 6 lbs to 0 lbs.
I have boiled the tank. Re-routed the fuel line around the header. Installed a clear fuel filter so I can watch it empty. 3 different mechanical pumps. 1 Carter, 1 Edelbrock and 1 Holley. I have ran a fuel line from the fuel pump straight to a can of gas, still no pressure after the car ran for 15 minutes. Help me.
Old 07-27-2007, 09:41 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Dropping Fuel Pressure
Carb must not be set up right and she's dumping all the gas. Should smell richas a pig too.
Also for the giggles, make sure the mount bolts didn't start walk'n on you.
