Old 07-26-2007, 08:53 PM
gene4545 gene4545 is offline
Need info on replacing 04- f150 manifold
Can some one tell how to replace the exhaust manifold on my 2004 f150. Is it a difficult job?
Old 07-26-2007, 09:25 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: Need info on replacing 04- f150 manifold
heritage or new body - what engine? either way they suck
-=-=-DANE-=-=-
Old 07-26-2007, 10:18 PM
New body style
Old 07-26-2007, 10:19 PM
anew body style and 5.4 engine
Old 07-26-2007, 10:37 PM
Exhaust Manifold RH Printable View (243 KB)
Material Item Specification
Metal Surface Prep ZC-31
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-00.
Disconnect the battery ground cable. For additional information, refer to Section 414-00.
Remove the RH heated oxygen (HO2S) sensor. For additional information, refer to Section 303-04B.
Remove the RH catalytic converter. For additional information, refer to Section 309-00.
Remove the starter. For additional information, refer to Section 303-04B.
Remove the parts in the order indicated in the following illustration and table.
Item Part Number Description
1 W701706 RH exhaust manifold nuts (8 req'd)
Installation Note
2 9430 RH exhaust manifold
Removal Note
3 9448 RH exhaust manifold gasket
Removal Note
To install, reverse the removal procedure.
Items 2 and 3: RH Exhaust Manifold and Gasket Removal Note
Remove the RH exhaust manifold lower studs.
CAUTION: Do not use metal scrapers, wire brushes, power abrasive discs, or other abrasive means to clean the sealing surfaces. These may cause scratches and gouges resulting in leak paths. Use a plastic scraper to clean the sealing surfaces.
Remove the RH exhaust manifold.
Discard the gasket.
Clean the sealing surfaces with metal surface prep.
Item 1: RH Exhaust Manifold Nuts Installation Note
Tighten the RH exhaust manifold nuts in the sequence shown.
Exhaust Manifold LH Printable View (309 KB)
Special Tool(s) Socket, Exhaust Gas Oxygen Sensor
303-476 (T94P-9472-A)
Removal and Installation
Remove the parts in the order indicated in the following illustrations and tables.
1 — LH front heated oxygen sensor (HO2S) electrical connector (part of 12B637)
2 — LH front HO2S
Removal Note
Installation Note
3 — LH rear HO2S electrical connector (part of 12B637)
4 — LH rear HO2S
Removal Note
Installation Note
5 9448 LH exhaust Y-pipe flange nuts (2 req'd)
6 9430 RH exhaust Y-pipe flange nuts (2 req'd)
7 W701706 LH exhaust pipe clamp
8 — Y-pipe support bracket bolts (2 req'd)
9 W701706 LH dual converter Y-pipe assembly
Removal Note
10 W701706 LH exhaust manifold nuts (8 req'd)
Installation Note
11 9430 LH exhaust manifold
Removal Note
12 9448 LH exhaust manifold gasket
Removal Note
Items 2 and 4: Heated Oxygen Sensor (HO2S) Removal Note
Using the special tool, remove the HO2S.
Item 9: LH Dual Converter Y-pipe Assembly Removal Note
Position the LH dual converter Y-pipe assembly aside.
Items 11 and 12: LH Exhaust Manifold and Gasket Removal Note
Remove the LH exhaust manifold.
Discard the gasket.
Item 10: LH Exhaust Manifold Nuts Installation Note
Tighten the exhaust manifold nuts in the sequence shown.
Using the special tool, install the HO2S.
-=-=-DANE-=-=-
Old 07-26-2007, 10:38 PM
sorry no pics - af blocks em. if you need pics email me at [email protected]
-=-=-DANE-=-=-
Old 07-27-2007, 06:26 AM
Thank you This helps a lot.
