Old 07-26-2007, 05:10 PM
donny h donny h is offline
Re: Grand Prix Off-Topic Thread
I need instructions for a 2001 pontiac grand prix to program a new key fob
keyless entry.
also programming instructions for a 2002 buick century Help would be greatly appreciated
Thanks
Old 07-26-2007, 07:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
keyless entry.
Thanks
donny h,
Welcome to AF.
Your post has been moved from the Grand Prix Off Topic thread to the regular part of the forum. Off Topic is intended for anything other than tech issues or questions related to your Grand Prix.
For your Buick Century checkout the Tips & Maintenance subforum at the Buick forums on AF.
RKE Programming 2001 Grand Prix
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Remove the key from the ignition.
2. Close all of the doors.
3. Remove the “ MALL PGM” fuse from the fuse panel. Use the legend on the fuse panel or owner’s manual to properly locate the “ MALL PGM” fuse.
4. Insert the keys into the ignition, and turn to the ACC position.
5. Turn the key to OFF and then back to ACC within 1 second.
6. Open and close any vehicle door. A chime will be heard when the system enters the programming mode.
7. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds. IMPORTANT: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8. Repeat the previous step on each additional transmitter to be programmed (including any existing remotes).
9. Remove the key from the ignition.
10. Install the “MALL PGM” fuse.
Timeslip 08/12/06
AF Community Guidelines
Old 07-27-2007, 10:43 AM
Burtnette Burtnette is offline
Re: Remote Keyless Programming for 2001 Grand Prix
Would this work for a 97 too? if not can you tell me how to do it for a 97?
Old 07-27-2007, 11:21 AM
BNaylor's Avatar
The procedure is similar but best to do the one specifically for '97 year models. See link below located at our Tips & Maintenance subforum. Good luck!
http://www.automotiveforums.com/vbul...d.php?t=652608
Timeslip 08/12/06
