fuel injector upgrade?
hi..is the vr4 injectors an upgrade for base model gts? or are they the same? or not even compatable?
2000 trans am WS6 FTP 85mm intake 85mm jet maf 85mm summit throttle body 85mm bbk ssi intake fast fuel rails 30lb ford racing injectors spohn strut bar msd ignition coils msd 8.5mm spark plug wires edelbrock shorty headers upgrade cam/ port and polished heads SMG dyno tuned ( 375 rear wheel hp ) magnaflow cat back slp y pipe umi bolt on subframe connectors umi rear control arms umi panhard bar 4:10 rear end gears stage 2 spec clutch |
Re: fuel injector upgrade?
http://www.stealth316.com/2-injectortypes.htm
different style of injectors. NAs have high-resistance injectors. TTs have low-resistance injectors. to make TT injectors work on the NA harness, you simply have to wire in some resistors. however, without increased airflow (forced induction, or nitrous oxide), upgraded injectors are a waste, and actually can cause your engine harm if not tuned properly. as i recall, jeff, you have some head work done? before upgrading injectors, i would get a datalogger and watch your O2s at WOT. also, you can check your IDC (injector duty cycles). but most likely the stock injectors will be able to compensate for the minimal additional air provided by head work (port and polish, etc). unless you are running upgraded cams, the stock injectors should work fine. bottom line, get a datalogger and monitor your engine parameters to first see if you are maxing out your stock injectors. if you are, then an injector upgrade might be a good idea.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
ya i was just curious to see because ya i have some work done for forced induction but like you said its not alot and ya i dont have cams done or anything, my car is running good now i was just wondering what the stock size was for injectors for my car vs. vr4? thanks for info
Theres no need for upgraded injectors in a NA 3s. The stock 210s are actually too much for it as is.
well i figured the air to fuel ratio was messed up a lil with some of the forced air that was added..guess not? ill probly just leave them alone..dont feel like messin with it..car runs good..dont fix what aint broken
hey while we were on the subject..who sells camshafts for the sohc 12 valve? i only need 2..not 4??? who sells em
You'll be lucky to find any. RPW in Australia has some but they are butt load expensive. GT Pro actually carried them for awhile as the US distributor and charged like $1400 for them.
Custom is about your only choice/
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
hmm..well what about like SL camshafts..or vr4 ones? are those compatible with base model ones? just use 2 of em? or would that just be to easy so they made it so you have to spend 1400$ to do this job?
i'm pretty sure the DOHC camshafts just don't fit on the SOHC engines.
forced induction is forcing air into the combustion chamber by means other than the vacuum of your engine. a supercharger, turbocharger and nitrous oxide are forms of forced induction. the oxygen atom in the N20 is what provides the extra power. 1 part oxygen for every 2 parts of nitrogen, and nitrogen by itself is diatomic and inert. and the oxygen is pure, so it provides a much better burn as compared to air.
Youre correct linebacker. There are no similarities between the SOHC and DOHC cam shafts. Even the cam gears are 100% different. You got to remember the SOHC is opening both intake and exhaust valves and on the DOHC one opens intake valves and one opens exhaust valves.
ya i didnt think so, just wondering...but thanks guys
