Old 07-26-2007, 03:27 PM
Karpvicious Karpvicious is offline
o2 sensor location?
i wanted to unplug my o2 sensor its already out of the exhuast ,but i dont know where the other end is in the engine
Old 07-26-2007, 04:42 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: o2 sensor location?
what year 3S do you have? turbo or NA?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-26-2007, 04:47 PM
1992 NA 5 speed
Old 07-26-2007, 05:08 PM
Linebckr49's Avatar
unless you have a cali-spec car (which i believe only came on the 94+ cars), then as an NA you have 1 O2 sensor. it is located in the exhaust just before the main catalytic converter. the wires run up through the bottom of the floor in the middle below the center console near the shifter.
93 3000GT base
Old 07-26-2007, 05:33 PM
is that where you can unplug it? inside the car by the shifter? i wanted to unplug the other end of the sensor so it wasnt connected to the ecu or engine anymore,i worked on the exhuast the other day n cut the o2 sensor n now the car wont start i was thinking if i unpluged the sensor from the engine itd start up
Old 07-26-2007, 06:41 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Car will start with no 02 sensor. If you cut wires and shorted them together you probly blew a fuse.
Old 07-26-2007, 07:22 PM
thats what happened i blew a fuse i replaced it n the car starts up fine =)
Old 07-26-2007, 08:40 PM
Stealthee's Avatar
Good to hear.
