Old 07-26-2007, 09:07 AM
chevyluver37's Avatar
chevyluver37 chevyluver37 is offline
weird noise in front
i have a 1990 civic 4dr sedan with a 1.5, everytime i drive it but only when i take off from a stop or moving in a lower gear i hear a noise like the gears are just barely hitting each other fuck i cant really describ it like the trans axel is out of oil, but i have already checked it and it looks fine so far it just keeps making it and its not the cv's cuz i just replaced those yesterday and it still does it so help please
Old 07-26-2007, 09:20 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: weird noise in front
Mine did something like that when one of the cv joints wasnt fully locked into the car..scary feeling and sound, mostly when decelrating in gear and then later while taking off...just had to pop it back in, but it turned out the clip was gone.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-26-2007, 09:22 AM
yeah at first i thought it might have something to do with it cuz both my cv's made a little popping noise so i thought they might but after changing them it didnt help the noise and mine does it accelerating and decelerating
Old 07-26-2007, 09:25 AM
FrodoGT's Avatar
Thats what I meant when I said taking off, accelerating.
Current project:
Rio Red 91 hatch.
Old 07-26-2007, 09:29 AM
oh ok yeah well shit i know both are good i just really dont want to have to pull the whole motor and trans out or send it to a shop too much money and time
Old 07-26-2007, 09:39 AM
FrodoGT's Avatar
Ididnt say they werent..just make sure they are in all the way lol.. It might not be that at all, but I thought my car was falling apart and it just turned out to be halfway out.
Current project:
Rio Red 91 hatch.
Old 07-26-2007, 09:42 AM
so pretty much just take and crawl under the car and then try to push them in is what your saying
Old 07-26-2007, 02:54 PM
viper-blue's Avatar
viper-blue viper-blue is offline
yeah..put your hand on the inner joint on each axle and give them a tug and see if you can pull it outta the tranny. I've had the same bloody problem and its such a pain in the ass! Always use a new circlip and make sure the axle is definately locked inside the tranny. Ive read a lot of posts on this same issue and it seems that anyone who replaces their own axles has this problem at some point. That noise you describe definately sounds like thats the problem. Unless it started before the cv replacement in which case you could have a tranny/clutch issue
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 07-26-2007, 11:53 PM
oh yeah my noise started before i replaced my axels they were not to bad i have done worse but yeah ill check them idk what it would be in the trans though i was trying to figure it out without having to do alot of work
Who ever said nothing is impossible never tried slamming a revolving door
Old 07-27-2007, 01:06 PM
well i checked both cv's and they are all the way in for sure but i did notice that it makes the noise if your at a light with the clutch out and you rev it up you can just barley hear it so idk if that is the clutch its self of like the bearing
Old 07-27-2007, 05:44 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
heh.. it's actually starting to sound like something is grinding against the pressure plate inside the bellhousing.. first you should try adjusting your clutch, to make sure it's not just the fingers on the pressure plate being bent in too far and contacting the clutch disc.
If that doesn't work, you'll need to pull the transmission and check the throwout bearing, grease the input shaft and bearing, if there is a grease fitting for the bearing, should probably just replace it with a new clutch kit tho... you're going to want to THOROUGHLY inspect the clutch disc, pressure plate, flywheel, and the fork that goes into the transmission to actuate the assembly.
quick fix to this... would be to check the bellhousing to engine block bolts... make sure they're all there, and tighten them as necessary. <(--- this ISN'T going to fix your problem, but it MAY make the clutch work a lil longer before it eventually fails, leaving you on a highway somewhere @ 1am.
The whole job (to replace with stock parts) shouldn't cost you more than about 150 bucks, and shouldn't take you more than 6-8 hours, if you've never done it before.
In return for your investment, as long as you drive the car properly, you'll have a clutch that will last longer than the rest of the car.
Old 07-27-2007, 06:05 PM
viper-blue's Avatar
like drip zone said that could be it...its a whole different story if it does it while your idling. kudos on the oem clutches. My buddy took my stock d16 with 324,000 on it and we checked the clutch..its definately the original, but the bastard was too cheap to replace it before we slapped it in his dx. that thing has been chattering away for two years, clutch slipping and all. Put your ear under the hood and try to trace the noise. If its coming from the tranny area its either a pilot bearing, or throwout bearing
