Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-26-2007, 08:21 AM
zubbie zubbie is offline
Turn Signal
I have a 98 Talon ESI. The left turn signal stays on, the bulbs do flash. The right side will not turn on, but will flash when emergency flashers are on. I have replaced the turn signal switch, the 4-way emergency flasher/ turn signal relay and the emergency flasher switch. I have began trying to chase wires, and go through other switches by process of elimination, if I am not on the right track please let me know, I am open to any and all tips or suggestions. I have located and checked all 13 grounding points on the car. (It is great to have a service manual.) Thank you in advance for any help.
Old 07-26-2007, 09:01 AM
marc-o-matic marc-o-matic is offline
Re: Turn Signal
sounds like you have a bad bulb on the right side.
do the bulbs light up(but not flash) when turn signal is on?
Old 07-26-2007, 09:25 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Turn Signal
Sounds like you have everything covered, I would try to replace the bulbs. There is 2 filiments in the turn signal bulbs. Maybe one burned out or something.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-26-2007, 10:44 AM
Re: Turn Signal
The right side will not even light up. I switched bulbs around. There are not any bulbs in the car at this point. And the left side continues to flash at a faster rate due to the lack of bulbs
Old 07-26-2007, 12:19 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Turn Signal
Hook a voltameter or whatever you call it to the socket of the defective side and see if there's at least some power flowing through it. Should be a lot, some, or none. Depending on what it is, we can take it from there.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-28-2007, 06:05 PM
Re: Turn Signal
There is no power to front or rear turn signals, on the right side. Tail light, brake light and back up lights work. Drivers side is fully functional. Would this be caused by a short. Or would a bad switch divert power back through somewhere? Thanks for any help you can give me.
