Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-25-2007, 08:48 PM
jmarwill jmarwill is offline
Towing with '99 4Runner
I have a '99 4Runner V6 LTD 4WD and am towing a wakeboard boat that weighs about 5500 lbs. I know the rated limit is 5000 lbs, what risks do I have for damaging the 4Runner? The 4Runner struggles up hills, but it gets there.
I have a trans-cooler and I change the oil, trans fluid and differential fluid religeously. When I tow, I keep the trans out of OD.
Any comments would be helpful. I'm trying to decide whether I need to buy a tow vehicle with a larger engine.
Thanks,
Jeff
Old 07-25-2007, 09:22 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Towing with '99 4Runner
Your biggest problem is overheating the transmission. Since you have an additional cooler, you should be fine. Just keep an eye on the transmission overheat warning light. Engine and rear end are not stressed much by your load, so no worries there. Make sure you use 93 octane when you tow.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-31-2007, 10:42 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
How often do you tow? daily? weekly? monthly?
If it's more than once a month consider a bigger tow vehicle. If it's every weekend, consider even more. 5000+ lbs is going to be way hard on a little 6 cyl truck.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 08-03-2007, 12:29 AM
legbreaker legbreaker is offline
Tow ratings are more than just how much power the vehicle has. Brakes is a major part of tow ratings.
So what if you can get a big load rolling. Can you safely stop it?
Old 08-03-2007, 11:00 AM
fourwd1's Avatar
AF -Advisor
Absolutely. A 5500 lb load should have trailer brakes.
89 4Runner - stock
