Old 07-25-2007, 07:50 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
2 quick ?s Moonroof and Y-pipe
Ok my moonroof wont go up or down like you have to pull the thing its on or the roof the little turn thing dont work. It started going out like a month or two ago then i got it set up to where it was down but i kept hearing bad windnoise and noticed it was like trying to lift up so i've got it off for now any way to fix or replace part #.
and y-pipe blow off how did you fix yours had a 3 in a month of driving so yeah....
Old 07-25-2007, 08:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 2 quick ?s Moonroof and Y-pipe
that's a common problem for the y-pipe on TT cars to pop off. the common remedy is to upgrade to a metal y-pipe. b/c its metal you can put some t-bolts or hose clamps on there and really clamp it down tight, much tighter than plastic.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-25-2007, 08:22 PM
Dreamspawn's Avatar
yeah i know its common just seeing what other ppl have done to fix it stealthee told me to do the tennis ball mod until i could get a metal one.
So moonroof ? anyone
