Old 07-25-2007, 07:42 PM
cuda_jim's Avatar
cuda_jim cuda_jim is offline
Cam Synchronizer wasted drive gear
I am in the process of replacing the cam synchronizer and need to know if the missing tooth on the cranckshaft damper is TDC when aligned with the Crank sensor? If so, will it be close enough to TDC to set the syncro? or do I need to be critical.
I am startin fresh because the syncro has a wasted drive gear and stopped turning. When it stops turning, so does the oil pump . Lukily I shut it down before there was any engine damage.
BTW: Is this acommon failure?
Old 07-26-2007, 02:31 PM
cuda_jim's Avatar
Re: Cam Synchronizer wasted drive gear
Oop's forgot to mention is a 98 Sable 3.0 2v, or a VIN code "U"
Thanks
Old 07-26-2007, 09:54 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
that'll be close enough - have done about 50 of em and that's what I use - it's a couple deg. off but never had a problem - the pcm will correct for minor errors.
-=-=-DANE-=-=-
Old 07-27-2007, 04:42 AM
cuda_jim's Avatar
Thanks rivguy, that eases my mind, I didn't want to re-do it. Since you've done so many of them, did any of them have a wasted drive gear or am I the only one?
Old 07-27-2007, 06:42 AM
normaly we find the shutter smashed where it hit the sensor - occasionaly we ahve noise problems as they seize but never have seen the gear go bad. either if the above could prolly cause the gear if it goes unchecked for a while.
-=-=-DANE-=-=-
Old 07-27-2007, 11:50 AM
cuda_jim's Avatar
That's kind of what I figured, I searched this site and others....nothing. The syncro was a little squeeky but nothing indicating a drive gear going south. Oh well, and thanks again for your input.
