Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-25-2007, 05:22 PM
dravella dravella is offline
Codes 17 & 19, 1992 SSEi
Need some advise on my SSEi.
What are the chances that both the Cam & Crank sensors are bad? Ran a code check and got 17 & 19, changed the cam sensor first, (easiest and cheapest) test drove it and all semmed well. Then all of a sudden without any kind of warning it stalled while at an idle, hard to restart and keep running, hobbled home and rechecked my codes...... 17 & 19 again.
Engine cooled down and restarted ok, ran very smooth for a while and then again stalled without any warning, justed died.
Should I change the crank sensor or look else-where for some other problem causing this stalling??????
Old 07-25-2007, 06:36 PM
maxwedge maxwedge is offline
A990 racer
Re: Codes 17 & 19, 1992 SSEi
How about checking for spark and fuel pressure before replacing parts? I see 17 and 18, could refer to a crank sensor or wiring from the cps to the icm or the ign control,module itself.
Old 07-27-2007, 01:57 PM
Hey THX for the Advise will check into it a little further
