Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-25-2007, 12:43 PM
Oprava Oprava is offline
Dropped rpm
When driving, the rpm seem to be correct. However, when I stop, e.g.,waiting for green light RPM drops once in a while to zero (motor is still running). Sometimes, it returns after a minute or so to normal (600), other times it stay at zero. Once I move the car the gage show normal rpm. However, on two occasions when I started to accelerate the engine died. I can restart the engine again and continue. This is unnerving since I never know when the engine will die. What is the problem and the fix for this? Thanks.
Old 07-27-2007, 10:10 AM
taillight taillight is offline
Re: Dropped rpm
Sounds like you have an intermitent wire disconect. Hard to find but try moving the wires around with the engine running. If it dies, look there.
Old 07-30-2007, 08:48 AM
Re: Dropped rpm
I checked the OBD codes but nothing was there but 55. Another observation. When the AC is on the RPM stays stable like a rock never dropping to zero at idle or in neutral.
Old 07-30-2007, 10:06 AM
Re: Dropped rpm
Check fuel pressure. You might even have to tape the fuel guage to the windschield and drive until it dies.
