Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-25-2007, 09:56 AM
Russ10 Russ10 is offline
1995 Eclipse OBD II Compliant?
Can anyone tell me if a 1995 Eclipse 2.0 non-turbo is OBD II compliant? I called the local dealer and they were useless!
Old 07-25-2007, 10:00 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 1995 Eclipse OBD II Compliant?
95 eclipse should be OBD1. I dont know what you mean by is it compliant to OBD2.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-25-2007, 10:18 AM
Basically "compliance" just means it will work to retrieve the codes. So you are saying it will only work with an OBD I?
Old 07-25-2007, 10:30 AM
Holset powered 420a
Are you just trying to use an OBD2 scanner or something to see cel codes. I dont think you would be able to use something for OBD2, it may work just not perfectly.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-25-2007, 11:03 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
I believe the 95s are OBDII compatible. They use the same ECU configuration as the 96-99s.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 07-25-2007, 11:57 AM
Is the ECU the same thing as the PCM? I checked the manual and can't find anything about the ECU.
Old 07-25-2007, 12:02 PM
I haven't used anything to read the codes yet. I'm trying to find out which scanner it takes. So far all I have used are the check engine flash codes but they don't make any sense. For a while I was getting 1-2-4-5-5 and then I was getting 1-2-5-5. I can't find anything that tells me what they mean. Those numbers don't show up in any code lists I can find.
Old 07-25-2007, 01:08 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
2g Eclipses are OBD-II. Although the government mandate wasn't until 1996, Mitsubishi implemented the OBD-II standard in all 2g cars. Since you are N/T, you should be able to get the key dance to work, which is I'm guess what you are trying to do. Try it again and see if you can get a more consistent reading from the ECU.
My guess is that the code is 12 - 55.
12 is the fault code indicating a power failure to the ECU and 55 signals the end of codes. So it looks like you are just being notified that the PCM lost power. Did you disconnect the battery while working on something before you got the codes?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-25-2007, 01:12 PM
Yes, they are the same thing.
1997 Spyder GS-T
5-Speed
Old 07-25-2007, 02:19 PM
Yes, I did have the negitive cable to the battery disconnected. It sounds as though my sensors and the pcm are good in that case. I get spark and gas but no fire. Timing belt maybe? By the way thanks for your help. I really appreciate it.
Old 07-25-2007, 04:13 PM
If you can get it to autozone they can scan it for you. You can also try other parts stores, a lot of the time they will rent their scanners out to people.
Old 07-26-2007, 07:14 AM
As for your spark problem, I really can't help you. I know nothing about the N/T's. Sorry.
1997 Spyder GS-T
5-Speed
Old 07-26-2007, 07:47 AM
Hey Spyder I found the problem. Broken timing belt. It looks like a real pain in the ass but at least I found out why it won't fire. Thanks again for all the help.
Old 07-26-2007, 12:17 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
That sucks. You may have internal damage to the engine. Bent valves, broken piston heads... can be quite extensive. Only way to find out is to rip the head off, check it all out, and fix what needs it. It's a pain in the ass, and if you've never done this before, take it to a shop.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-26-2007, 03:25 PM
Apparently the car was sitting still at idle when it stalled. Of course then it wouldn't restart. I'm hoping that may have saved it or is that wishful thinking? Also, once I have the timing belt removed if I can rotate the cams 360 by hand the valves should be O.K. right?
