Old 07-24-2007, 11:34 PM
milladog milladog is offline
up & down idle problem...
ok i have a 97 gtp, i have replaced plug wires, plugs and the car runs fine. then some days i will start it up and it will idle rough up and down and sometimes it will trigger the engine light and the code is high idle. Does anyone know what can be the cause??? I will be at a street light and the car will jerk while in gear because of this idle issue....HELP...
Old 07-25-2007, 05:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: up & down idle problem...
Sounds like a dirty throttle body and IAC valve. Try cleaning them out with carb cleaner and see if it straightens out.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-25-2007, 01:05 PM
thanks, will try that...
Old 07-25-2007, 07:21 PM
FISH96 FISH96 is offline
ewq
Old 07-26-2007, 05:31 PM
eippermx's Avatar
eippermx eippermx is offline
Anyone have some suggestions for name brands of carb cleaner that are safe to use to clean the throttle body, MAF sensor, etc.?
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
Old 07-26-2007, 08:06 PM
ewq
Old 07-26-2007, 08:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Originally Posted by FISH96
THE ONLY BRAND I AM ABLE TO RECALL AT THE MOMENT IS CRC. I AM QUITE SURE THERE ARE OTHER MANUFACTURES OF SIMILAR PRODUCTS.
REGARDS,
FISH96
Fish96,
Please use lower case whenever possible otherwise you are shouting according to forum etiquette.
I use STP brand spray Throttle Body and Air Intake Cleaner and Gunk brand for MAF sensor.
Timeslip 08/12/06
AF Community Guidelines
Old 07-27-2007, 11:44 AM
Firstymer Firstymer is offline
Hi,
I face the same problems with my 00' GP SE. The car engine rpm gauge would idle up and down for some odd reason. So are you saying what causing it is the throttle Position need cleaning? And that I should use Air intake cleaner and spray Throttle Body, Gunk brand for MAF sensor. If so, please reply, I can use the extra help...
