Old 07-24-2007, 11:19 PM
Nalayah Nalayah is offline
6th Cylinder Plug... has won
Ok, on our 3800 SII '99 grand prix, I've been working on the spark plugs. I've gotten cylinders 1-5 plugged, but the 6th one seems to be in there in such a way that it's impossible to get out. Half the area that the ratchet attatches to (I have no idea what it's called) is buried into the side of the engine, the passenger side of it that is.
Is there ANY way to get it out? As a DIYer, I'd rather not have to take it to a mechanic and have my wallet lightened immensely. However, it needs to be replaced badly, judging by the condition of the other plugs.
Thanks again in advance. Also, a hint: Gloves aren't that great of an investment. After your fingers get shredded to bits, you stop feeling pain .
Old 07-25-2007, 06:03 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 6th Cylinder Plug... has won
you need either a wobble extension or u-joint for your ratchet so you can clear the oxygen sensor to get on that plug. There is nothing in the way down in the cylinder head, unless dirt and debris have gotten in there and are blocking access to the plug.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-25-2007, 08:13 PM
troy1 troy1 is offline
AF -Advisor
I got mine out with no problems. regular spark plug socket and extensions and a ratchet. I think I used a 1" and 3" extension.
Old 07-26-2007, 08:42 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Although you can work around it you can remove the bracket attached to the exhaust manifold that holds the 02 sensor wiring harness and remove the 02 sensor. That opens up the area to remove #6 and will prevent any damage to the 02 sensor. Plus protect your hands from getting cut or screwed up.
Timeslip 08/12/06
AF Community Guidelines
Old 07-27-2007, 12:11 PM
Thanks, that's exactly what I needed to know . No wonder the banner says "May cause dependancy" XD.
