Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-24-2007, 01:02 AM
<Lucci>gs <Lucci>gs is offline
Send a message via AIM to <Lucci>gs
water into cold air intake
if water were to get splashed on my filter could that lead to some deep deep problems
because everytime it rains a lot when im driving i always get afraid of that happening so i avoid puddles and such things like that
but would could be the worse thing to happen?
and if anything were to happend wat should i doo?
99 Eclipse gs (1oth anniversary edition)
NOOO TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT!!!!
MOds-
Dropped (Eibach springs)
TRadesonic Cold air intake
Old 07-24-2007, 01:26 AM
steviek's Avatar
steviek steviek is offline
Re: water into cold air intake
you should always avoid puddles regardless if you hav a CAI or not. Most of the time if water does get in there it will make your car bog down. It is extremely unlikely that permanent damage will be done to your engine (most water would just converted to steam). But it could do something more like short out electrical shit. If it happens and your car is bogging really bad just turn it off and wait till it dries or try and blow on it Its really not that big of a deal its more of an inconvenience to my understanding but hey I could be wrong.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-24-2007, 01:37 AM
thanks for the heads up
its just that i have heard that it could cause some problems thats why when i drive in the rain i almost shit my pants
so now i know not to worry
and plus i mean u probally are right about this cuz if it rains a lot im sure water would get on the filter and nothing has happend yet
MOds-
Old 07-24-2007, 02:13 AM
smoke121212's Avatar
smoke121212 smoke121212 is offline
cut your intake pipe, this way theres less chance of it sucking up water.
1996 eclipse gs
cold air intake, thats right im super fast now! wooooooooooooooooooooooooooooooo lol
If a man says something in the woods and there are no women around to hear him, is he still wrong?
Old 07-24-2007, 08:17 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The only permanent damage you could do would be to hydrolock the motor
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-24-2007, 03:23 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Hydrolock is fun. That's about the worst that can happen, which is pretty bad if you really think about. Need a new motor then.
If it rains a lot and there's puddles all over the place, you may want to consider cutting your CAI and lift it off the ground a little bit. I had my CAI dropped all the way to the ground. Was actually sitting on the splash shield. I was driving on the tollroad one day doing 90 and it had just rained. Little did I know that the one sectino of road floods and I ran right through it. Car bogged and came really close to dying. If I wasn't doing 90, I would've probably hydrolocked it. Not fun. I cut it alittle that same night.
As stated above, most of the water will just convert to steam, but it depends on how much water is sucked in. Also, water on the filter will cause some performance/fuel problems. Will slow you down and ruin your gas mileage until it drys/or gets sucked in.
In short, don't sit where your filter is in a puddle and start revving. And stay away from big puddles.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-24-2007, 07:44 PM
so should i just cutt it or should i just get a new one?
MOds-
Old 07-24-2007, 08:35 PM
david-b's Avatar
Dave is THAT guy
I have to ask... is this a serious question?
75 Monte Carlo
Old 07-24-2007, 08:36 PM
dont waste the money just cut it! like david, mine was sitting on the splash guard as well (kinda pushing it down). all i did was get a hack saw cut it about 6-8 inches and i was good to go. it takes all of 5 minutes to do, depending on how thick the pipe is. good luck.
1996 eclipse gs
Old 07-25-2007, 12:56 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
AEM makes an air bypass valve that installs in your intake to bypass sucked up water.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 07-25-2007, 09:19 AM
Holset powered 420a
The bypass valve is just another foam element that goes between your intake pipe, the motor can suck air in from there if the filter is under water and the water can drain out if it makes it that far. Only problem is that hot air gets sucked into the motor also which kills all the performance you get from a CAI.
98 Eclipse GS Turbo
2001 BMW 325i - DD
