Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-23-2007, 08:04 PM
Wattsyurz's Avatar
Wattsyurz Wattsyurz is offline
Send a message via Yahoo to Wattsyurz
E motor timing anomoly
Recently got another Camaro, 91 RS. I've been going through all of the maintenance and tune up steps after curing the overheating - BTW, mine had about twenty pounds of leaves, dirt, SAND, and grass wedged between the A/C fins & radiator - no idea on how that much got in there. Anyways, I got around to inspecting ignition timing, and what should be simple is vague at best. The underhood gives 0 deg btdc at idle. No idle figure is mentioned there or in the manual. It does say idle is computer controlled. While jumping the ALDL A-B, w/ wire disconnected at dist, is just off scale advanced. If I set it at 0, it's definitely wrong. Anyone have a clue on how to make the procedure work as expected?
'67 Camaro 350 - driver, '83 Z28 305 (off the ECM), and T5
'91 RS 305 T5, 2000 C5 2000 Trans Am
I don't drive the Fords
Old 07-23-2007, 10:06 PM
Firebirdlad03 Firebirdlad03 is offline
Send a message via AIM to Firebirdlad03
Re: E motor timing anomoly
lol just wanted to say i love your 67...i would die for one of those...
Mitch
92 Firebird formula...
Old 07-25-2007, 03:16 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
It should still say idle speed, even tho is controlled,. Off the top of my head I want to say 550 at operating temp. You don't have to jump the ALDL, just sidconnect the single TAN wire on the passenger side firewall and go from there.
Old 07-25-2007, 09:18 PM
Wattsyurz's Avatar
You would think the idle speed would be listed, but it's not. I could get a pic of the decals, but AF pic posting didn't work last I checked.The tach reads just shy of 1000. Got the other issue regarding the advance, but the idle speed is still a mystery. I'll check the tach with my Sunn, cause I hear the dash model isn't accurate. Thanks all!
Old 07-26-2007, 10:14 AM
wrightz28's Avatar
In dash one is junk. I usually end up doing the final setting by ear personally.
