Old 07-23-2007, 04:42 PM
hot3000's Avatar
hot3000 hot3000 is offline
Wtb: Fwd Mtx For 96 3kgt
if anyone has one I need it to do the ATX to MTX conversion.
Thanks
(ive posted already on 3SI)
Old 07-24-2007, 12:12 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Wtb: Fwd Mtx For 96 3kgt
FYI, an MTX from any year will bolt up just fine. the difference, however, is in the axle size. 91-92 have smaller splined axles (smaller diameter) and 93+ have larger splined axles. also, be sure you get the intermediate shaft (driver side axle that goes into the trans) in addition to the correct axles for that year transmission.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-24-2007, 06:55 AM
hot3000's Avatar
thanks for the info
