Old 07-23-2007, 04:38 PM
mr3000 mr3000 is offline
HKS AFR fuel computer on my n/a?
would the HKS AFR Fuel Computer be a wise upgrade on my n/a...it says its designed for cars with light mods done to them.
Old 07-23-2007, 05:50 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: HKS AFR fuel computer on my n/a?
What have you done? Bigger injectors, higher flow fuel pump, more aggressive cam, more aggressive timing, intake, exhaust?
The only reason you would find any use from that is if you were adding more air than the stock computer could compensate for or adjust for bigger injectors/higher fuel flow.
Old 07-23-2007, 06:11 PM
well im about to do custom exhaust and intake, not sure what else....would it give me any gain?
Old 07-23-2007, 06:19 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
no.. not really.. save your money and buy cam's..
Old 07-23-2007, 06:43 PM
Polygon's Avatar
The Red Baron
Yeah, an exhaust and intake aren't enough alone to warrant an air/fuel controller. Save the money for something better. Like Jason said, cams are your best next step.
Old 07-23-2007, 09:42 PM
ok, will do
Old 07-24-2007, 12:17 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i have the HKS S-AFR...i believe that's what you're referring to. i've installed it but haven't tuned it b/c i don't have any significant mods (YET!) that the stock ECU can't handle. however, i may tune it a bit up top when i install my adjustable cam gears.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
