Old 07-23-2007, 01:07 PM
stageact stageact is offline
Proramming Needed
Can anyone provide the programming instructions for the remote to a 2002 Blazer's GM Aftermarket remote.
GM P/N 12490830 MODEL/FCC ID: EZSOEMTX
THANKS!
Old 07-23-2007, 10:32 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Proramming Needed
try this:
With all doors closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel. The keyless entry receiver will respond with the following in order to indicate that the receiver is in the programming mode:
Locking the doors
Unlocking the doors
All transmitters (including extras) must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond with the following:
Locking the doors.
Unlocking the doors.
Repeat the last step above for each additional transmitter then turn the ignition switch to the ON position in order to exit the transmitter programming mode.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 07-24-2007, 05:59 PM
hernandez3674 hernandez3674 is offline
GO to here.. worked for me like a charm....especially if you buy one on ebay...
http://programyourremote.com/
