Old 07-23-2007, 12:39 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Grounding the head unit.
I want to get some opinions on this. I have an 89' LeBaron GTC as a project car. Some of you may know that Chrysler uses ground straps on thier stock head units. There is no question that I replaced it with a 10ga Stinger cable.
However, I am getting ready to swap the entire system in my Stealth. I called around to find a local place to make a ground cable. They all act as if I'm stupid and tell me that it grounds in the harness. I'm not a moron, I know that. I just thought it was a good idea to ground with some bigger and better cable than the harness provides.
Am I wrong? If not, do you guys know of any good places online to buy a pre-made cable. I'm look for 10ga and no longer than 1 1/2 feet in length.
Thanks,
Clint
Old 07-23-2007, 01:04 PM
PlayStation3 PlayStation3 is offline
Re: Grounding the head unit.
all you need to do is find bare metal and for head unit you don't need 10 guage wire 14 wire is what i used. if you have a system all the headunit needs power for is to read the cd and normal opreration it does not need it for the amp inside of it.
Old 07-23-2007, 09:13 PM
AWP9521 AWP9521 is offline
I always used the factory grounding strap fastened to the back of the head unit (some units have a predrilled hole with a matching screw, others have a clip with a stud and nut) and also fastened the black wires from the head unit to the same location and never had a problem at all, one of those redundant kind of things.
The reason being is the shield on the Antenna connection is directly coupled to the case of the head unit, that gives an extra ground connection for the antenna system in case the ground at the vehicle body at the antenna end is lost.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 07-24-2007, 06:07 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I never use the factory harness ground, I always run a 14-16 ga black wire to some metal in the dash cavity.
