Old 07-23-2007, 11:06 AM
hawk362's Avatar
hawk362 hawk362 is offline
What is the best thing to Port under the hood of my car for the money???
So I know for a fact I want to stay N/A dont ask me why I'm not sure yet, but anyways what would you guys reccommend to port polish under the hood of my car, would help the most hp wise, and be worth the cost??????? opcorn:
Old 07-23-2007, 11:21 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: What is the best thing to Port under the hood of my car for the money???
heads.. thats about it
Old 07-23-2007, 11:25 AM
hawk362's Avatar
What could i be looking at possible 5hp
Old 07-23-2007, 12:03 PM
jason_bet's Avatar
I would think with that and mild cams you could see 25+.. but I dont no crap about NA.. so that is just a guess
Old 07-23-2007, 12:15 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
That really depends on the port job. Porting and polishing isn't about removing material, it is about removing material from the right places. So, you might only get 5hp from a crap job. Find a good machinist that knows these heads and I'm sure you would see more. Pair that with a cam and a three angle valve job and you could see a good deal of power.
I would call someone at Dynamic Racing, see if they can help you or at least get you pointed in the right direction.
Old 07-23-2007, 07:59 PM
Zeiss's Avatar
Zeiss Zeiss is offline
you'd be better off turbocharging..
Bye V8...
Old 07-30-2007, 03:12 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
yup..these guys are right.i have my NA heads port and polished, which by the way isnt a cheap thing to do..and depends on who does em to see what kinds of power..anywhere from 10-30 hp gains i would say..i also have my manifold and throttle body port and polished and my lower intake plenum..might as well do it all while its out..try a whole mess of bolt on hp adders first..cheaper..easier..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 08-08-2007, 11:31 PM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
i have a couple of questions
is there a difference between the NA and TT heads? if so, would putting on the p&p TT heads be worth it on a base model related to cost?
also, how much of a difference is it to actually have those other things ported and polished??
is there any other throttle body that can be swapped that anyone knows of?
i fix things that aren't broken
Old 08-09-2007, 12:10 AM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
VR4 heads will flow a little better.
As for TB stick with stock. There are set ups making HUGE horsepower on stock TB. The TB is not a restriction.
