Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-23-2007, 02:29 AM
87BoxClassic's Avatar
87BoxClassic 87BoxClassic is offline
Thick white smoke on startup
I have a 1987 Caprice it's been running fine, got a new carb, and new tranny.
But when the car is cold and i start it up it blows thick white smoke for a few seconds. Is this bad??
Also where is a good spot for a kill switch, and which is better fuel cut off or battery cut off?
Old 07-23-2007, 02:38 AM
Re: Thick white smoke on startup
I've been searching around the forums, i know it's not coolant in the oil so i'm leaning towards the light blue smoke and also it gives a little black smoke then it doesn't smoke at all. But what i cant find is should i take this and get it fixed or will it be fine?
Old 07-23-2007, 07:01 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
You probably have bad valve stem seals which allows oil over night to leak into the combustion chamber. The repair is not that expensive, best left to a good shop in my opinion.
Bob
Old 07-23-2007, 10:43 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
What Bob said.
If it's not using much oil, and you don't mind the cloud, you can leave it as is as long as it's not smoking while you're driving it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-23-2007, 11:00 AM
bobss396's Avatar
Mine uses some oil at 168k. I go with 20w-50 in warmer weather and still go through a quart in 1000 miles on the average. In my case, the fix is not worth it and has no bearing on the emissions. My spark plugs are always clean when I change them.
Bob
Old 07-23-2007, 01:25 PM
silicon212's Avatar
Confoundingly Lucid
To answer your other questions on the kill switch and cutoffs - unless your car has the 4.3 V6, it will be carbureted and carbureted cars use mechanical fuel pumps. No cutoff possible on the fuel system on these cars (unless, again, it has a V6 in which case it's EFI with electric pump).
The best place to put a kill switch is the place that works best for you. If you're wondering what to run the kill switch from, the BAT lead on the distributor is the best case.
Old 07-23-2007, 02:01 PM
mike561 mike561 is offline
hey i think i know you, but yeah i'd like to know about a killswitch too of which is better.
2006 Chevy Cobalt LS
Old 07-23-2007, 06:06 PM
I live in boca also, dunno if i've seen you around town or not.
Silicon what is a place to order a good kill switch, have any websites?
it's 5.0 305 carbed so i'd have to get the other one
Old 07-23-2007, 09:35 PM
kahjdh's Avatar
kahjdh kahjdh is offline
I've done valve seals, they're not bad but getting to them is another story. Just need some specialty tools and a weekend.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
