Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-22-2007, 10:55 PM
rc77 rc77 is offline
Mystery Plug
I just got done replacing my ignition switch on my 97 regal LS, and while on the floor looking up I notice a loose plug hanging. Has 2 wires comming out, one is black and the other is green with a white stripe. It has the letters PED on it along with A and B above where the wires plug into. Everything I tested after the replacement seems to work so I wasn't sure if I just didn't notice it before or if it came off during the ignition switch R&R.
In the reply below I will post 2 pics of the plug From the side/front.
Old 07-22-2007, 10:57 PM
Re: Mystery Plug
Old 07-23-2007, 06:55 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Mystery Plug
It is not used so I would not worry about it.
Timeslip 08/12/06
AF Community Guidelines
Old 07-23-2007, 06:38 PM
Bassasasin Bassasasin is offline
Re: Mystery Plug
Looks like part of the shift interlock system.
If I'm correct, this may be a extra connector to a harness that can be either used on a Centry/Intrigue (on column) OR a Regal (on console) allowing interchangability to install in different models at factory.
When you press the brake pedal the shifter can come out of park.
It has the same A B... and comes from Brake PEDal and GReen/White wire.
What ME worry? NO.. unless your shift interlock when you press your brake pedal has quit.
Bass
(not an expert)
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 07-23-2007, 07:36 PM
BNaylor's Avatar
Re: Mystery Plug
Bass
(not an expert)
Sorry but you are absolutely 100% incorrect and by your own admission not a Regal expert nor any Buick for that matter that I have seen. You should worry about your own incompetence in giving dumb advice. Did we not have a discussion about this in the past?
It is a connector not used that is part of the multifunction switch.
Timeslip 08/12/06
Old 07-24-2007, 01:05 AM
Re: Mystery Plug
Thank you for all your time and help , it is greatly appreciated.
